Andrew Shpagin Posted July 9, 2009 Share Posted July 9, 2009 There you can download V3 BETA 2 for Linux Both 32 and 64 bit versions available www.3d-coat.com/~sergyi/3D-Coat-V3-BETA2.tar.gz Several notes about possible problems: If you have any visual issues (like solid white window on 3d-coat start up), please set "System -> Preferences -> Appearance -> Visual Effects -> None". For navigation you can use either "Super" ("Windows logo") or "Alt" key, but for better experience please set "System -> Preferences -> Windows -> Movement key -> Super". How to manage swap files under Linux. Show your swap files with Terminal command swapon -s If the list is empty you should create swap file with Terminal commands sudo dd if=/dev/zero of=/swapfile bs=1M count=2000 (or whatever size you want in megabytes) sudo mkswap /swapfile sudo swapon /swapfile To make swap file permanent sudo gedit /etc/fstab Add at the end of the file and save /swapfile none swap sw 0 0 Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/ Share on other sites More sharing options...
Member habernir Posted July 9, 2009 Member Share Posted July 9, 2009 hi when i run 3d-coat for 64 bit its say /3d-coat-64: error while loading shared libraries: libtiff.so.4: cannot open shared object file: No such file or directory how can i solve this problem? i have fedora 11 Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23351 Share on other sites More sharing options...
Member StriderX Posted July 9, 2009 Member Share Posted July 9, 2009 Open a terminal and type: su put in your root password then run this command ln /usr/lib64/libtiff.so.3.8.2 /usr/lib64/libtiff.so.4 then try to run 3DC Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23359 Share on other sites More sharing options...
Member Morpheus Posted July 9, 2009 Member Share Posted July 9, 2009 Hi Andrew 3d-coat appears to change the permissions of the .dmrc file and home folder after running the program. I need to reset the permissions every time after running the program. The bugs I previously reported have been sorted. Thanks!! Erik p.s I purchased 3d-brush V2.10 back in october 2007. What will be the cost to upgrade to V3.0 for linux? Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23390 Share on other sites More sharing options...
Andrew Shpagin Posted July 10, 2009 Author Share Posted July 10, 2009 p.s I purchased 3d-brush V2.10 back in october 2007. What will be the cost to upgrade to V3.0 for linux? I think 80$ - standard upgrade price V2->V3 General price notice: V2(Win)->V3(Linux) 60-80$ (depends on purchasing date as usual) V3(Win)->V3(Linux) 0$ but only if Win license will never be used since getting Linux license, win key will be disabled V3(Win)->V3(Linux+Win) - 40$. Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23408 Share on other sites More sharing options...
Javis Posted July 10, 2009 Share Posted July 10, 2009 I think 80$ - standard upgrade price V2->V3General price notice: V2(Win)->V3(Linux) 60-80$ (depends on purchasing date as usual) V3(Win)->V3(Linux) 0$ but only if Win license will never be used since getting Linux license, win key will be disabled V3(Win)->V3(Linux+Win) - 40$. Very fair! I will be upgrading to dual win/Linux. Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23410 Share on other sites More sharing options...
Applink Developer haikalle Posted July 10, 2009 Applink Developer Share Posted July 10, 2009 This sounds great! I'm taking win/Linux too. Thanks a lot Andrew! Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23414 Share on other sites More sharing options...
Member habernir Posted July 10, 2009 Member Share Posted July 10, 2009 thanks StriderX. i still cant believe that there is sclupting tool for linux autodesk and pixologic can't do it but you do it!!!!!! one man against this two giant . JUST ONE WORD WOOW!!!!! keep the good job my friend. Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23421 Share on other sites More sharing options...
Member Morpheus Posted July 10, 2009 Member Share Posted July 10, 2009 Thanks Andrew, I see it is not possible to order the Linux version via the website yet. Is it possible to get a serial number for the beta version for the time being? regards Erik Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23426 Share on other sites More sharing options...
Javis Posted July 11, 2009 Share Posted July 11, 2009 Thanks Andrew,I see it is not possible to order the Linux version via the website yet. Is it possible to get a serial number for the beta version for the time being? regards Erik Hey there, I hope so too! Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-23519 Share on other sites More sharing options...
Javis Posted July 16, 2009 Share Posted July 16, 2009 A linux bug: Ubuntu 9.04 64 bit Opening an existing file (tried with 3 different files) that were created with 3DC in windows will not open, and the interface starts going haywire. Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-24019 Share on other sites More sharing options...
Javis Posted July 16, 2009 Share Posted July 16, 2009 A request: Is it possible to use the Right CTRL and ALT keys? Right SHIFT works. I am left handed and it's a huge strain to use the left side of the keyboard like that. PS- Huge thanks again for a Linux build. It's performance is actually WAY faster then the windows 64 build... Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-24020 Share on other sites More sharing options...
Advanced Member kay_Eva Posted July 17, 2009 Advanced Member Share Posted July 17, 2009 A request:Is it possible to use the Right CTRL and ALT keys? Right SHIFT works. I am left handed and it's a huge strain to use the left side of the keyboard like that. PS- Huge thanks again for a Linux build. It's performance is actually WAY faster then the windows 64 build... for reals? too bad I'm not good enough at Linux to get my tablet to work but I'll boot into it really fast to check it out for myself dang looking at Andrew's post I remember how much I don't know about Linux even though it's installed on here. Let's see... I'm just curious anyone care to tell me how much of a speed difference there is in Linux vs Windows. I'm probably not going to take the time to try to set all of that up being a Linux noob unless I know it's worth it. Last time I installed Linux and it took me a lot of tries to do it for the sake of blender sculpting back before I knew about 3d Coat only to find out there there wasn't much difference ... Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-24023 Share on other sites More sharing options...
Applink Developer haikalle Posted July 17, 2009 Applink Developer Share Posted July 17, 2009 Yep! right ctrl + alt would be nice to have. also the smaller enter button dosen't work and I'm using that quite a lot when setting number parameters. kay_eva: You can try to install ubuntu 9.04. Your wacom tablet will work in there and you don't have do anything. Problem right now is that I'm not able to get it work in 3d-coat. In gimp it works but not in 3d-coat. About speed it is good already. I will do some testing later when linux version is released. Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-24037 Share on other sites More sharing options...
Javis Posted July 17, 2009 Share Posted July 17, 2009 Oh yes, I had forgotten about that, thanks haikalle. The numerical enter key is essential too. I use it quite often. I am using Ubuntu 9.04 as well, as haikalle said, Ubuntu supports it right out of the box, GIMP works, but 3DC doesn't. However, I think this might help with that, I found this resource invaluable: http://linuxwacom.sourceforge.net/ Also here is some general information about Ubuntu with a Wacom from the Ubuntu 9.04 FAQ: Wacom tablet hotplugging Wacom tablets now are enabled automatically when attached, no longer requiring xorg.conf modification. Button mapping configuration is not yet supported, but can be set manually by adding an fdi file to /etc/hal/fdi/policy/. So the keys buttons, but are not correct (coming from windows), they are backwards (again compared to windows), and you cannot customize them. Link to comment https://3dcoat.com/forum/index.php?/topic/2984-3d-coat-v3-beta2-for-linux/#findComment-24039 Share on other sites More sharing options...
